I just got my door seal replaced and now the door just doesn't feel the same..
the door has to be shut hard and pops open when you open the door...also the locking mechanism is having problems when i open the door when its locked the lock won't go up and the way and gets hung up or jammed because of the pressure...Has anyone had there door seal replaced and experienced this problem...the guy at the body shop said i have to break it in...also the two doors seem to line up differently with the interior now....give me your thoughts please!
Spray some silicone onto a rag, and then wipe it on the seal.
The heat will make it a bit more compliant. The Silicone will help to squish on the door a bit more. It'll also take care of any squeaks you might get.
it seems as though they did take it off because when you are sitting inside and the door is closed the dash and the door don't line up very well especially on the top part....the door sits lower now than the other side.
