I need help aligning my bumper properly.
My bumper won't line up right, it has a gap between the car and the bumper and it sticks out too far.
<center>
Passenger side
<img src="http://i230.photobucket.com/albums/ee211/MySTG3S4/Car%20Accident/IMG_2779.jpg" alt="Photobucket - Video and Image Hosting">
<img src="http://i230.photobucket.com/albums/ee211/MySTG3S4/Car%20Accident/IMG_2778.jpg" alt="Photobucket - Video and Image Hosting">
<img src="http://i230.photobucket.com/albums/ee211/MySTG3S4/Car%20Accident/IMG_2777.jpg" alt="Photobucket - Video and Image Hosting">
<img src="http://i230.photobucket.com/albums/ee211/MySTG3S4/Car%20Accident/IMG_2776.jpg" alt="Photobucket - Video and Image Hosting">
Driver side
<img src="http://i230.photobucket.com/albums/ee211/MySTG3S4/Car%20Accident/IMG_2775.jpg" alt="Photobucket - Video and Image Hosting">
<img src="http://i230.photobucket.com/albums/ee211/MySTG3S4/Car%20Accident/IMG_2774.jpg" alt="Photobucket - Video and Image Hosting">
</center>
After installing my ASP FMIC my bumper does not line up properly, yes, I did check to make sure that the IC piping are not the problem. I did search and found out that you can use this:
<img src="https://www.audiworld.com/tech/pics/ext46-bumper1.jpg">
But except this and turning the bumper support screw up a few mm what else can I do?
AND, how do fix the pass side bumper that sticks out?
This is very frustrating.
<center>
Passenger side
Driver side
</center>
job under warranty. They had actually bent the sheet steel the mount is screwed into a little. I pulled the bumper off and just pushed and pushed until it was back in a bit, then put the bumper back on.
Good luck!
Good luck!
AudiWorld Expert
if not, line up the side to where its supposed to be, and with the bottom of your palm... give it a good wack it should snap right in.
if neither of these work... the ghetto solution is, a sheet metal screw.
I really don't' know.... i took the stupid thing off and adjusted the side brackets by banging them in just a bit. I also turned the screw on top of the bumper support holder about 4-5 mm higher so the bumper sits higher.
Brdman*
07-14-2005 09:05 AM
A4gasam18
05-04-2005 11:32 AM
demolition_x
07-20-2003 10:19 PM
