I need more info on the best RPM range to shift for the fastest quarter mile time.
#31
how does the Gtech compare to actual track numbers?
and your G's across the powerband should overlap with your torque curve right? Does the Gtech give you torque #'s? is it possible to do torque versus RPM?
-Alex
-Alex
#32
...so you can watch the G's reduce as the RPMs climb, match a specific G to a speed in a gear and then compare the G's produced at that same speed in another gear. That's how I came up with the shift points in the my post linked below. That was on a Stage II S4 with an older version of APR software.<ul><li><a href="https://forums.audiworld.com/s4/msgs/467353.phtml">https://forums.audiworld.com/s4/msgs/467353.phtml</a</li></ul>
#33
hp numbers. Although, they both have their pro's and con's. For the S4, due to its tiny turbos, torque is our advantage. I'm willing to bet that the same holds true for the RS4 turbos. Granted you'll shift in the 6K range, but you most likely won't benefit from going to redline.
#34
I get to the track. I understand staying in the power band, but if you short shift when the RPMs drop on the next gear, doesn't that get you below the power band?
#36
hp is still torque * rpm.
and *WHEEL* torque is hp * gearing
No matter what your gearing, you still have more WHEEL TORQUE at high engine rpm than lower rpm; measuring engine torque alone does not yield you shift points until you take rpms into account.
IF you short shift, YES it is due to torque, but only insofar as you have enough torque to make up for the fact that you just lost a few krpms.
#37
winding it out. The turbos just fall on their faces above 6,000 so the 6,000 to 7,000 run is just wasting time.
NickS
13
11-05-2001 09:54 AM
Eternal706
06-14-2001 05:05 PM
What is the best RPM to shift at in each gear? Please respond, I am always bouncing off rev limiter.
ChrisS4
10-07-2000 12:50 PM
