I think I am hearing engine KNOCK. Please Help.
#17
hard to say if you aren't throwing any codes, your kv's are fine, etc.
unless a kv sensor or two is gone wonky.
a leakdown (NOT just a compression test) might not be a bad idea at this point.
but if your car is running ok, your EGTs look ok, and your CF's aren't going nuts, maybe its just some random engine compartment rattle?
#18
how about redline?
and are you hearing knock at low rpm or near the top?
i would say to be safe knock it down to below 20psi, and try not to run anything more than 16-17 or so at redline.
