I think my thermostat is going bad...my water temp only gets up to the first hash mark
in 20 degree F weather here in Wisconsin. In 40-50 degree outside temps it may get to the second. Where should my water temp be? Needle right in the middle of the guage?
My 2001 S4 has about 73000 miles. I recently replaced the Coolant Temp Sensor. VAG-CAM revealed that to be faulty.
Could it be that the thermostat is stuck open? Is this something that would be covered under the certified warranty?
TIA
Joel
TIA
Joel
Might as well get the timing belt job done, since thermostat replacement and coolant replacement is part of it. That is... if you haven't had your timing belt job done yet.
for a thermostat job so might as well pay the extra $400 to get the rest done. At 73,000 miles, you are due for it anyways if you haven't done it already.
taking the bumper off, the rest is bolts and connectors very easy.
i would say this is a great DIY job.
forum should be able to answer all your questions
