If you have long term idle fuel trims between -4% and -6%, you should ______. (fill in the blank)
Other than the most obvious (check for leaks and bad MAF)
Car is homebrewed-modded stock airbox, 90mm Buehn MAF with bosch sensor, lightning 42 lb injectors
This is really dependent on your idle g/s... with such a modded intake tract, could be normal. You also may need O2's sometime in the future, but unless you have another problem... leave it alone.
JBear::FATS
08-31-2004 11:57 AM
Greg PAW
12v V6 Discussion
18
03-18-2004 01:07 PM
PearlA4_1
12v V6 Discussion
01-24-2004 04:42 PM
Catamount90
01-06-2003 08:57 AM
