I'll ask in the audio forum, but have any of you non-bose guys replaced the front speakers?
I'm gonna get a small sub for some low end, but my fronts crackle whem I'm listening to trebley stuff, like Pennywise or something. Is there a cheapish replacement that works with the headunit and such? Mainly just need better tweeters...
I read in the audio forum it might help just to get some MB Quarts in front
However, I don't want to start spending a lot on a stereo. I put a $3000 stereo in my truck before I bought the s4 and had tremendous buyer's guilt because my truck had rattles, and it totally ruined the sound on quiet songs. My car rattles a bit now too, so it doesn't make sense to spend much at all.
Anyone every just replaced the speakers without adding an amp? Does it even do anything to the sound?
The problem with upgrading with the stock Bose amp is
that the stock amp has built-in equlization for the Bose speakers. If you install aftermarket drivers then the EQ will be wrong. In some instances it might sound OK, but since you're mismatching the speakers, it's a shot in the dark.
Sorry, no experience with non-bose
But if you want to improve the sound, go with larger speakers up front (From 4" -> 5.25) using the MB Quart A4 adapters.
I'll say that the most drastic improvement in sound came when...
I replaced the head unit. At first I kept the stock head and replaced the front speakers and added a sub. It was ok but the sound quality was still lacking a bit. The bass was way overemphasized no matter what I did to the so called hidden EQ. The high end always seemed a little dead. So finally I got fed up and replaced the head unit. After that, things are completely different. So I would say, save your money until you can do it all at once.
<img src="http://pictureposter.audiworld.com/19077/dash.jpg">
It's not that I don't have the money, it's that I don't want to spend it on audio :)
Maybe I'll just get a sub and speakers first and go from there. Local shop quoted $250 for a sub, and $100 for installing fronts. Not bad.
rageman
07-12-2006 08:36 PM
channelv
01-18-2005 01:16 PM
channelv
01-16-2005 11:08 PM
agower19
15
02-25-2004 11:02 PM
thershey
07-13-2000 08:29 AM
