I'm about to do my TB. Is there a consensus on who has the best kits?
I bought the Blau kit in May then the damper failed in August and I bought the replacement parts from PureMS.
<a href="http://www.blauparts.com/proddetail.asp?prod=GH21113%2D1B">http://www.blauparts.com/proddetail.asp?prod=GH21113%2D1B</a>
<a href="http://www.purems.com/products/product.php/II=1154">http://www.purems.com/products/product.php/II=1154</a>
Just did mine, I would make sure to change both belts, both tensioners (both will die on you), water pump, thermo, 2 pulleys, and obviously coolant. I'd use the cam lock kit if you have access to it, the bar itself isn't necessary, but the chop sticks tool is vital. Just make sure the 2 cams and crack to no move, mark them all and you'll be fine.
you'll end up having to go to the dealership needing a couple of things other kits bring. Like their Extreme or deluxe super kit(forgot what they really call it).
Steve Trac, Sec 303
19
08-03-2005 07:02 PM
dancs1.8t
07-12-2005 03:54 AM
wakko
04-13-2005 03:12 PM
