I'm having problems
My VAG won't communicate w/ my car. We tried using Daryl's VAG and it works fine w/ his laptop.
I don't have any background programs running, nor do I have an 'sync' programs running.
The attached image are the errors I get when 'testing' the VAG to see if it connects.
The left side of the image is VAG 311-2. The first error is COM1. The bottom left error is COM3.
The right side of the image is VAG 303-1. The first error is COM1. The bottom right error is COM3.
Any idea guys?
<img src="http://pictureposter.audiworld.com/15288/vag-com.1.jpg">
Any idea guys?
it's ActiveSync not releasing the COM port on your laptop. Go into ActiveSync Connections Settings (under file menu) and uncheck "Allow serial cable or COM port" option.
Worked for me.
Worked for me.
but not the VAG tool. Might be your adapter or the cable as 808Guy mentioned.
Did you try using your adapter/cable with their laptop?
Try posting this on the VAG-COM forum if you haven't already.
