Implemented some changes in the newest ECUx Templates (v11beta)
Old 10-30-2006, 12:10 PM
AudiWorld Expert
Mark P's Avatar
Default Implemented some changes in the newest ECUx Templates (v11beta)
If you want to try them out, feel free to grab the latest from here:
<a href="http://ctny.audiworld.com/mark/s4/ecux/template11/">http://ctny.audiworld.com/mark/s4/ecux/template11/</a>
And if you do give them a try, please let me know any issues you encountered, etc.
Here are examples of some of the output of each:
<a href="http://ctny.audiworld.com/mark/s4/ecux/template11/example_data_single/" target="_blank">Single-gear template example</a>
<a href="http://ctny.audiworld.com/mark/s4/ecux/template11/example_data_multi/" target="_blank">Multi-gear template example</a>
The one for multigear runs is basically complete (pending user comments). The single-gear pull version just has the additions to the 1st tab - I'm waiting until it's been refined enough before porting the changes to the other tabs.
<u>The biggest change</u> is that this version doesn't require one to use a specific group file to match the template. You can use your own group file, with variables in any order. You merely paste the corresponding column headers so the file knows what the data is.
<u>Helpful Hint:</u> When you first open up the csv file from your log, the cursor will already be in cell A1. Click ctrl-shift-&lt;right_arrow&gt; and it will highlight the header row. Then just do a ctrl-c and ctrl-v to copy/paste it into the templates.
In addition to that, I've also changed some of the Auto-Calculators to be more flexible...
<u>In the single-gear-pull template:</u>
- In the FATS calculator, I added the calculated/corresponding MPH for 4200/6500, so it is immediately obvious if the results are from a car with different gearing. Also it can be used to remind us what the startMPH and endMPH are for our normal FATS pulls - this info can then be used in the Any-Speed-Range calculator below for other cars to compare to ours.
<img src="http://ctny.audiworld.com/mark/s4/ecux/graphs/fats_auto_calc.png">
- Previously there was a FATS+ 4000-7000 auto-calculator and corresponding graph. I've now changed this to an Any-RPM-Range Auto-Calculator, so the user can choose which range they want to measure time for. I left the startRPM and endRPM and 4000 and 7000, so it defaults to a FATS+ calculator, but a B5 A4 owner (for instance) could change that to the range for their CAPS time (3800-6500).
<img src="http://ctny.audiworld.com/mark/s4/ecux/graphs/any_rpm_auto_calc.png">
- I've also added a similar Any-Speed-Range Auto-Calculator. It could be used to check you car's performance compared to other cars results in magazines, etc (ie 50-70mph). Another reason for adding it was to allow better comparison of "FATS" to other cars. That is, cars that have different gearing would give non-comparable FATS results if you only were looking at the 4200-6500 RPM range. Now, those other cars can use this to enter ~57mph and ~91mph to see what their apples-to-apples FATS times are.
<img src="http://ctny.audiworld.com/mark/s4/ecux/graphs/any_speed_auto_calc.png">
<u>In the multi-gear template:</u>
- I replaced the 0-100mph calculator with a similar Any-Speed-Range Auto-Calculator.
<img src="http://ctny.audiworld.com/mark/s4/ecux/graphs/any_speed_auto_calc_multi.png"><ul><li><a href="http://ctny.audiworld.com/mark/s4/ecux/">http://ctny.audiworld.com/mark/s4/ecux/</a</li></ul>
Old 10-30-2006, 12:22 PM
Member
PSmalls::AnalRetentiveNumbNut's Avatar
Default Very cool, Mark. I downloaded both templates, will give 'em a try.
Your templates are going to get me thrown in jail.
Old 10-30-2006, 12:25 PM
Junior Member
Mihnea's Avatar
2nd, gonna do a few runs tomorrow
Old 10-30-2006, 12:30 PM
Member
My2ndS4's Avatar
jeebus. I really need to get ecu-x
Old 10-30-2006, 12:32 PM
Ah10@WMS's Avatar
I downloaded the new version and when i copy and paste previous log, the graphs are not showing up?
Member
jprice@CPS's Avatar
Default nice.. How about an ANY RPM time calc? Then us A4 folks can easily get CAPS times.
Or am I the only A4 folk that uses these? :-p
wagongotya's Avatar
*sigh* 2nd
Old 10-30-2006, 12:33 PM
AudiWorld Expert
Mark P's Avatar
Default you need to copy the corresponding header colum labels...
read my post above where it says "the biggest change is"
Old 10-30-2006, 12:34 PM
AudiWorld Expert
Mark P's Avatar
Default how about you read my post before asking questions ;-)
look at the second really big green square in my post above ;-)
Member
Works so awesome, Mark. I'm glad I can finally plug in old logs that don't use all the same variable
Quick Reply: Implemented some changes in the newest ECUx Templates (v11beta)
