Implemented some changes in the newest ECUx Templates (v11beta)
#21
I can't get 60-130 time using 4K RPM in 3rd gear to 7K RPM in 4th gear unless I adjust MPH for tire size. I could easily use the MPH vs tire size calculator on your site and find out what RPM in 3rd gear is 60MPH and what RPM in 4th gear is 130 MPH, then insert those RPM in X gear values.
I run 225/40/18 tires.
#22
AudiWorld Expert
Explain this more:
"I can't get 60-130 time using 4K RPM in 3rd gear to 7K RPM in 4th gear unless I adjust MPH for tire size."
What's causing you not to be able to get that? Why can't you just use 60-130 in the Any-Speed multigear calc?
If you had on stock tires, does this change anything, and if so, how?
Just trying to understand more...
#23
Hmm, just checked your site and it says 7K RPM in 4th gear on stock tires should be 130 MPH but ECUx doesn't log the speed that high (126.x at 7K RPM, 128.x at rev limit). I'd rather have ANY RPM calc, just use 4K RPM in 3rd to 7K RPM in 4th.
