info on rear install of V1?(between rear passenger and rear window)
a while back i saw a post on some guy describing how he install a box to cover the entire v1 behind the rear passenger of the car.. wonder if someone can point me to the article. i spend several hour and still can't found the archive...
Which go on to say, the search capability of this BBS is not sophiscated enough. I have send multiple email to the tech person of this board, and he have not reply : (
Bad idea...
Why put 3,800lbs of steel between you and the source of the most serious threats?
Stick it in the front where it belongs, or sell the V1 to someone who will be able to make use out of it, you might as well get a P.O.S. radar detector if you're going to use it wrong.
found it!!!!!!
took me 2 hours. but i found it.
this search engine really suck.
it need to be able to perform recursive search(instead of phase match)
george. i don't know why you oppose to this idea so much.. you posted it so many time against this..
it is not that bad. read it.<ul><li><a href="https://www.audiworld.com/forum/m/s4/msgs/62292.phtml">https://www.audiworld.com/forum/m/s4/msgs/62292.phtml</a</li></ul>
LI-S4
11
06-03-2004 05:05 PM
unregistered user
05-30-2004 02:59 PM
Skibum the Original
02-28-2003 03:30 PM
