Input on low boost an vag codes
I'm not spiking over 13psi in any gear. I pressure tested and fixed all the tiny leaks I found, rechecked and was good but still 13psi spike. The only thing I found was that the purge valve vibrated a good bit. Is this a sign of it failing and this doesn't effect boost at all correct? I do have a evap code for a large leak( guessing gas cap et.c) Also I need to replace my driver side 02 now. Would this really be the cause for such low boost? I don't think it is. My feelings are I may need a new n75.(how do I check duty cycle to tell if it's going bad?) My Codes are :
4 Faults Found:
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
Thanks everyone for your help
4 Faults Found:
P0455 - 35-00 - -
BenM@University Audi
04-26-2001 06:26 AM
