Installed an Infinity Basslink yeterday. Short write up / pic.
#13
of course everything else would be useful (how you routed your power cable, where you connected the ground (I assume there is a ground?)). I am non-Bose and would like a little more punch to the bass, and this little puppy looks perfect.
Thanks.
Thanks.
#17
I'm guessing this isn't the best solution but I hate running through the firewall, got to be a source for power that you could steal and put a fuse on it. Thoughts?
#18
On some days, there is this weird magnetic force that pulls me in and I get all my aggressions out on some poor unsuspecting little white ball.
#19
I just went through the ECU housing (with grommet of course). There is tons of room in there. I made sure I used wire with good insulation to keep any noise generated away from the ECU itself.
#20
this product is best for easy install, good bot great sound and bass control **** - it will never, ever compare to properly choosen custom box, sub(s) and amp but as stated takes a couple hours to install. Also run bigger wires than necessary so easy to upgrade later as most of the time is pent running wires about 10 mins to actualy screw the basslink in.
BTW buy online at etronics less than 200 IIRC.
snowbooch
A4 (B7 Platform) Discussion
06-07-2006 08:25 PM
SporTTy
05-22-2006 01:10 PM
fentoozler55
04-12-2005 04:03 PM
Audi Eh
10
03-20-2001 07:22 AM
