Intermittent vibration/shudder when lifting off throttle???
Occasionally I get a vibration/shudder when I lift off the throttle while still in gear. If I get back in the throttle even just a little and then lift again it will usually go away.
My first guess would be rear diff mounts and I should have the new PureMS mounts at my door any day now. I might also need to get the ASP one or wait for PureMS' solution.
I have ASP motor and trans mounts so it should not be these (although I need to double check that everything is tight).
Have any of you experienced anything similar and if so what was it?
TIA
TIA
and the aluminium spacer was moving around. Right on the middle of the bar.
Question is do you even have a DTS?
when I put the diff mounts in. Might try the hockey puck mod for a while too.
comp to the street version that they were lose as well. I put loctite on those but I will check the trans and maybe motor mounts again as well
I'm curious because I get a very strange and audibly vibration as well and it comes from this location only when the car is running fully hot and often on the highway. I have no clue what it could be though... and no one has been able to help me resolve the issue thusfar.
as you know vibrations can be pretty tricky to isolate some times.
Is yours all of the time or just when you lift?
The upper ones I was able to crank down a 1/4 turn and that seemed to tighten things up a little. Not sure if they backed out or not but I don't have loctite on those (although they have loosened up in the past... just didn't have loctite on hand).
