JewelP stasis s4 is the best. The ride was perfect
We changed damping and everything in 5 minutes. I haven't ridden in a car that handled better than hers. If anyone if familiar with Carbon Canyon, off of Lambert and the 57 freeway in Orange County, you know how the turns are. We hauled *** through there. No Body role perfect flat turns at high speeds. Sorry S4MadMan, I think I will pay more to get her suspension.
Full motor sport suspension
<center><img src="http://www.stasisengineering.com/images/Suspension_MS_Main.jpg"></center><p>
MOTOR SPORT
STaSIS Double Adjustable Coil Over Kit:
* Available: A4, S4, A6, S6
‡ 4 STaSIS custom-valved KONI dampers
‡ double digressive damping
‡ double adjustable (rebound & compression), wide band
‡ adjustable while installed on vehicle (rebound and compression)
‡ lightweight aluminum threaded damper bodies
‡ height adjustable
‡ 2 STaSIS custom upper rear spring perches
‡ 4 linear rate Hyperco springs
‡ 450 lb. to 1000 lb. spring rates
‡ balanced and adjusted on SPA damper dynamometer
MOTOR SPORT
‡ height adjustable
