JH Motorsport solid shift linkages are in stock, finally! Thanks Jason.
Old 11-16-2007, 06:07 PM
Banned
Mike@VAST's Avatar
Default JH Motorsport solid shift linkages are in stock, finally! Thanks Jason.
<a href="http://vastperformance.com/shop/product_info.php?cPath=21&products_id=106">shifter linkage upgrade</a>
<img src="http://www.vastperformance.com/images/JHM_S4_Linkage_vs_stock_assembled.JPG">
Old 11-16-2007, 10:19 PM
Member
audikillsbmw's Avatar
Nice, but expensive : (
Old 11-17-2007, 04:46 AM
RASTAMN: is IRIE's Avatar
Hey piggie, is that component seprate from the kit?
Old 11-17-2007, 07:14 AM
Grifnsqest's Avatar
Default I recently had my shifter adjusted...
it is the stock shifter. And I was having trouble with the 1-2 shift. I loosened the two screws for lateral pivot, and front-back position. I made a few adjustments, and tightened them back up.
The shifting is a lot better now. But should I expect this to happen again? I was chatting with my mechanic, in all his years of Audi service, he has never had to adjust a shifter like that.
Do you think this linkage upgrade would help any movement I experienced? Or was it just a matter of a screw being loose? It's a stage 3 with about 166K miles.
Thanks
Old 11-17-2007, 08:40 AM
Stätus Josh
Guest
Posts: n/a
Default How hard is the install??
Is the JHM shifter a worthwhile upgrade without this? or is this what makes it so good?
Old 11-17-2007, 08:42 AM
Stätus Josh
Guest
Posts: n/a
From what I can see, yes it's seperate from the short shifter
Old 11-18-2007, 04:01 AM
davenew's Avatar
Default no, the jh shifter is very worthwhile without this
I wouldn't even attempt to install that linkage unless I had the engine out for something else, unless the stock bushing was completely shot. The cup on the end of the shift rod is crimped to the stock bushing and it would be a real pain to remove with the engine installed.
The JH shifter gets rid of the slop of the stock plastic shifter ball while the new linkage does the same at the trans end of the shift rod.
I will install that JH linkage the next time my engine is out.
KillA6
11
05-13-2008 12:01 PM
llonman
11
10-20-2006 11:49 AM
klone121
Audi 100 / A6 (C4 Platform)
11-15-2005 04:37 PM
GETTINGBLOWN
16
09-21-2005 10:17 AM
99SilverA4
04-02-2005 01:31 PM
Quick Reply: JH Motorsport solid shift linkages are in stock, finally! Thanks Jason.
