JP Engineering or AWE Tuning's Downpipes?
Old 03-27-2002, 08:00 AM
Junior Member
sissupr's Avatar
Default JP Engineering or AWE Tuning's Downpipes?
Can someone explain the difference in the two, if any?
Thanks...
Old 03-27-2002, 08:05 AM
Member
JTravinski's Avatar
Do JP's match up to the stock exhaust? if so, that seems more restrictive than AWE's. Not sure tho.
Taner Halicioglu's Avatar
Default Main difference is the flex-joint, and the AWE's come with test pipes
Also, I hear the O2 sensor placement might be slightly different? Someone said they had issues with the AWE DP's, but that might have been user error, I don't know... Todd/Someone from AWE want to clear that point up?
Anyway...
the JP Eng ones use a "normal" mesh type flex joint, whereas the AWE ones have a ball-and-socket joint that allows you to remove the main cats and put in test pipes.
Both are 3" tapered to 2.5" where the precats used to be.
RyanS4 had a post about the differences somewhere... hopefully he'll reply to this post and give you the URL
-Taner
Old 03-27-2002, 08:07 AM
Member
Dangler {/KAWF} BUMP's Avatar
Default Taner - I think you covered all the objective points. Regarding AWE dp's and the 02
sensors - they have instructions that talk about where the second 02 sensor is and how to make it work - its really straight forward.
Old 03-27-2002, 08:21 AM
Cyan S4's Avatar
Taner how do you like your pipes?
Old 03-27-2002, 08:23 AM
P. Bauer's Avatar
*both* AWE and JP Eng taper from 3" to 2.5"
Old 03-27-2002, 08:35 AM
Member
Todd/A.W.E.'s Avatar
Default Yes, it was installer error. Install sheet adjusted for clarity. Note about downpipes in general:
<center><img src="http://www.awe-tuning.com/pages/gallery/awe_s4dp/images/awe_s4dp_neck_closeup.jpg"></center><p>
Not all downpipes currently on the market fit correctly.
Basically, every S4 downpipe design on the market is handbuilt.
The complexity of the jigs ensures that every single handbuilt example will fit without issue. There can be no variances in routing, since packaging is so tight on the S4.
We had to tweak our jigs several times during prototyping to makes sure all possible obstructions on the car were accounted for. Since there are so many obstructions, it is not a simple case of running a tube from point A to point B.
Too many fabricators rush their jigging, and since the products are handbuilt, variations in build can lead to interference issues once on the car.
Even though the jig may ensure that the downpipe starts and ends at the exact same spot each time, if there is even a .25" variance in the tubing while going from start point to end point, all of a sudden you'll have a set of downpipes that rub during usage. Remember that the whole drivetrain will shift during acceleration and decelleration, along with the downpipes.
The bottom line is that we have spent so much time ensuring proper fitment of the S4 downpipes that you do not have to worry about fitment issues with this labor intensive install.<ul><li><a href="http://www.awe-tuning.com/pages/shared/part_detail.cfm?PMaI=1&PMoI=4&PEI=6&PP=s4_27t_exha ust.cfm&PPT=Exhaust&IL=AWESflo_DP">AWE Tuning S4 Downpipes</a></li></ul>
Old 03-27-2002, 08:39 AM
Thanks for the clarifications...
Old 03-27-2002, 08:40 AM
Default Awesome... gotta get them installed now ;-)
debating if I want to do the 7-8hr job myself, or fork over the $600 for the install... hrm...
Old 03-27-2002, 08:42 AM
Cyan S4's Avatar
glad you like them bro =)
Quick Reply: JP Engineering or AWE Tuning's Downpipes?
