just installed a boost gauge(more)
just had a test drive. Ifound out that it read -20 when idle and if you floor it, it spike up to 15psi and will settle at around 11psi. Is this normal?? BTW, I got the garrett chip
At idle, the car will run vacuum, i.e., it is sucking in air, so thats why it is negative boost. At full throttle you will see 15 psi, sometimes more depending on the weather. Then usually, at higher rpm's you will see the boost back off.
Ned
Ned
I got the Apex and read in psi, I tap it on the vacumm line in front of the engine. only tested 1st and 2nd gear though.
typical results similar to chipping a 1.8T...your boost is set at 15 psi, but as your revs get higher, your turbos cant flow enough to maintain 15 psi, so you see your boost (and power curve) taper off in the upper rev range.
bradb
bradb
NoFHoes
13
04-23-2002 04:31 PM
S_FOH
12-18-2001 06:27 PM
DocWyte
11-14-2000 06:30 AM
