Just pulled these codes off yesterday. Any help would be awesome...
Address 01: Engine
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G 0003
Coding: 06611
Shop #: WSC 06325
11 Faults Found:
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-10 - - - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00160
Shop #: WSC 06325
1 Fault Found:
01542 - Yaw Rate Sensor (G202)
13-00 - Adaptation Limit (Mul) Not Reached
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 D
Component: B5-KOMBIINSTR. VDO D11
Coding: 02264
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 15208
Shop #: WSC 06325
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 10036
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End -------------------------------------------------------------------------
The most I have ever had... Something tells me it's not looking good for the BrokenRocket.
Address 01: Engine
Coding: 06611
Shop #: WSC 06325
11 Faults Found:
P0421 - 35-00 - -
Coding: 0273004284
Shop #: BB 24334
Coding: 00160
Shop #: WSC 06325
1 Fault Found:
Coding: 02264
Shop #: WSC 00000
Coding: 15208
Shop #: WSC 06325
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00101
Shop #: WSC 10036
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Coding: 00201
Shop #: WSC 00003
1 Fault Found:
00-00 - -
hhv011
08-19-2012 07:17 PM
internecine
05-05-2011 05:40 PM
s4florida
04-10-2005 08:04 AM
