just wanted to say my APR stealth exhaust sounds 10x better with cats installed!
The annoying resonance/rattle sound at 2800 rpm is gone. It's worth whatever hp I lose with not running the test pipes. The car feels just as fast but I've been working to much lately to do any logging.
Does APR code use the rear O2 sensors? I only replaced the front two when installing stage 3. While finally swapping the cats in the other day, I noticed the rear )2 sensors have some very heavy carbon buildup. Since the code doesn't throw a check engine light for test pipes, I assume the rear O2 output isn't used..
as factory. If the cats are missing you will have a cat code/DTC per bank on the B1S2 and B2S2 sensors(working) but the CEL won't light. Readiness still sets, even w/o cats lol, that part is pretty cool in-itself, won't get you passed on an emissions VAG/OBDII check(DTCs) but if they don't pull codes the readiness will pass you, even w/o the cats.
pep-1972
04-06-2007 03:03 AM
davenew
08-21-2006 07:11 PM
k04/rs6north
03-27-2006 04:14 PM
would APR st2+ software be that much slower than GIAC X? I just want to get rid of this CEL cause of
BlackS4tt (Josh)
27
01-26-2005 12:15 PM
