k04 upgrade...
#11
wow I'm a retard. good check, thanks.
but more importantly. I do not want to blow my throttle body boot (TBB) off anymore. Need a fix before I can take her out on the road. Scares me to think it will blow off at night and I can't limp my why home...
Seriously folk, need some help here. Do I really need an APR Bi-Pipe? Or can I get away with some better clamps and clean off the throttle body with some gasoline and stick it with some hairspray and some tighter clamps?
Mean time I'm gonna take out the AMS ECU and replace with stock until I get this figured out. Not worth blowing 2500$ in work/parts.
http://shop.achtuning.com/achtuning-...-version2.aspx
It probably is a problem with the clamps, but with increased boost levels you'll want something reinforced anyway. I've heard hairspray works, too, but you still want better clamps at a minimum.
#12
#13
well its finally out of the shop. apparently they didn't know how to reclock the turbos' ??
had the TBB blow off once, reseated it and tightened up well (so I thuoght) and it blew off again. I REALLY do not not to blow these turbo's.
What is the recommended cure here? The APR Bi-Pipe? Or can I get some better clamps and use hairspray?!![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Also had a weird thing happen when accelerating the dash would beep twice and the ebrake 'brake' light would flash a couple times...
Thanks for the help.
this **** is funny!!!
#14
I got some new worm drive clamps on there, seems to be holding up, haven't pushed it yet tho.
Also new is, when its dead cold, it will not go into reverse, and 1st and 2nd are notchy has hell...
#15
Notchy when cold is fairly normal. Not going into reverse is a problem.
I doubt its a lack of trans fluid. Is it possible that something, somehow, got mis-aligned?
When I put in my short shifter, it took me 45 minutes to get it so that all my gears lined up correctly.
#16
It's parked in the garage at night. Cold as in the water temp is at zero, and oil temp is pegged cold. So it might be like 68deg outside here in Tampa. After the water temp reaches the middle and the oil temp gauge pops up some reverse is fine.
I'm thinking I will have to do a shifter realign... seems odd though.
jwktn
10-12-2007 04:00 PM
SilverS4AVWP
14
09-09-2006 09:17 PM
Ballin00TTq
02-10-2003 09:02 PM
