K04 upgrade questions - my K03s may be dying...
So some of you seem to think my rebuilt turbos are junk....well if they are I certainly do not want to put another set in. If I go K04, I dont want to do major stuff, I just want stock fueling, stock programing, stock exhaust. AWE and APR kits both have injectors and require programing upgrades. I do have an APR chip, but I dont have it in my car. Also both kits say "6 Speed" and I have a Tiptronic. Is it possible to get just the turbos, hoses, MAF, and leave it at that? For now I want to go bare minimum with maximum reliability. In the future when I really have money I can change that. Would anyone have a cost for this minimum upgrade?
Thanks
Carter
Thanks
Carter
Depending on the shop, the labor could be anywhere between $1000 - $1500.
The turbos, probably ~$2400 w/inlets, I think...somewhere around there.
Is $2150 off some guy on VWVortex for NIB K04's. If I can find that stuff for those prices, I'm all over it.
*2001 Audi S4 6spd, Silver/Onyx:
/GIAC\EVO DVs/AWE DTS\VAST SS/FK Tails\
K04 Turbos - SPP $1950.00
K04 Inlet Pipes - ECS/EPL $549.95
APR RS4 Intercooler Kit - ECS $1044.00
RS4 K04/KO3 Gasket Install Kit - ECS $74.65
Samco Upper Intake Hose Kit, Black - ECS $139.95
Upgraded Turbo Feed/Drain Oil Lines - ECS $404.80
OEM RS4 Engine Mount (2) - ECS $219.90
OEM RS4 Transmission Mount - VAST $150.00
VAST Poly Snub Mount $26.00
Piggie Pipes $400.00
ECS Tuning Ultimate Plus Timing Belt Kit - ECS $344.95
Auto Speed TSB $295.00
Plus Install, Plus Clutch/Torque Converter Other Transmission Upgrades for TIP, Plus Tuning/Fueling, Dont forget you need to stop and handle the extra power so you need suspesion and brakes too. The list goes on.....
piggie pipes, timing belt, tranny upgrades...Half of that I dont want or need at the moment.
