KW variant 2 question pls help (M)
I noticed on the front coilovers that you can adjust the rebound with a allen key. How is the back adjusted because there is no allen key slot. Do i have to remove the shock from the housing??
pls help guys im confused TIA
Rob
Rob
they have Koni shocks, right?
On front shock you use an allen key to keep the rod from rotating when loosening/tightening the top nut.
Adjustment on Koni shock is done at the top of shock body, where the rod enters the body. There's a metal plate with 2 holes that rotates...
I've never seen KW coilover, but ANY front shock for our car will have this allen thingie on top of the rod...
And yes, you do have to remove the shock in order to adjust...
my2000apb MEGABOOST
05-13-2008 10:12 AM
RidgeS4
01-11-2003 10:37 PM
