In layman's terms what does the first and second number mean regarding oil (example: 5w40)
Oil weight, or viscosity, refers to how thick or thin the oil is. The temperature requirements set for oil by the Society of Automotive Engineers (SAE) is 0 degrees F (low) and 210 degrees F (high).
Oils meeting the SAE's low temperature requirements have a "W" after the viscosity rating (example: 10W), and oils that meet the high ratings have no letter (example SAE 30). An oil is rated for viscosity by heating it to a specified temperature, and then allowing it to flow out of a specifically sized hole. Its viscosity rating is determined by the length of time it takes to flow out of the hole. If it flows quickly, it gets a low rating. If it flows slowly, it gets a high rating.
Engines need oil that is thin enough for cold starts, and thick enough when the engine is hot. Since oil gets thinner when heated, and thicker when cooled, most of us use what are called multi-grade, or multi-viscosity oils. These oils meet SAE specifications for the low temperature requirements of a light oil and the high temperature requirements of a heavy oil. You will hear them referred to as multi-viscosity, all-season and all-weather oils. An example is a 10W-30 which is commonly found in stores. When choosing oil, always follow the manufacturer's recommendation.
initially you want the oil to quickly flow through the engine to lubricate it and as the engine warms up, you want the oil "thicker" to protect, lubricate and cool.
"thin and thick" don't really mean that in viscosity but it's the easiest way to visualize that.
So at it's coldest, the oil is 5 weight and at its hottest its 40 weight ie 5w40
Since the density of the liquid is a variable, I don't think there is an "easy" conversion factor.
Just my 2 cents.
Just my 2 cents.
