Leaking RS4 oil cooler, I needs a part number!
Shop can't look up RS4 parts... Seems this line is leaking something awful. We think it is the braided line that runs into the filter (which is the one I highlighted?).
I've called around and am waiting for replies.. but with a part # we could hopefully order it immediately. Thanks!
<img src="http://pictureposter.audiworld.com/67457/rs4oilcooler.jpg">
My DIY guide has the full parts list - make sure you get the right line - the ETKA dia is reversed
<ul><li><a href="https://www.audiworld.com/tech/eng61.shtml">https://www.audiworld.com/tech/eng61.shtml</a</li></ul>
you could have the hose replaced
I just had a flexible section of a saab hydraulic clutch line replaced at a local industrial hose place (Hampton Rubber). He even brazed adapters to the tubing after cutting the flex section out, to adapt to threaded fittings that he crimped on the nice braided hose. It was only $30-35 with labor. That oil hose would be easy for them to replace.
pink shrimp
05-02-2008 05:13 AM
