Lemmiwinks question
Old 10-26-2004, 10:21 AM
BLK01S4's Avatar
Default Lemmiwinks question
Guys I was reading something about our ecu's and how it does fuel management. I was wondering if I make changes to the fuel system like Accel and Decel fuel loads will the computer learn this stuff out and will I be back at square one? Also does the same apply to Primary and Secondary fuel?
Old 10-26-2004, 10:55 AM
Mike2kS4's Avatar
Default ECU can adjust up to 25% but it takes a while for it to learn...
Lambda regulation plays a key role in this.
Old 10-26-2004, 10:57 AM
Mike2kS4's Avatar
Default oh, and accel and decel are only if you're having issuse on/off throttle...
Otherwise, leave it alone!
Old 10-26-2004, 11:00 AM
Member
Disappear lika Ghost's Avatar
what kind of issues? please clarify. :-)
Old 10-26-2004, 11:02 AM
Mike2kS4's Avatar
Stumbling, Hesitation... only when your gas pedal position changes.
Old 10-26-2004, 12:02 PM
BLK01S4's Avatar
Default Re: oh, and accel and decel are only if you're having issuse on/off throttle...
Yes I believe my car is going rich when I floor it going to confirm that on the dyno on Sat. Do the accel and decel settings ever get learned out?
Old 10-26-2004, 12:05 PM
BLK01S4's Avatar
Default Re: ECU can adjust up to 25% but it takes a while for it to learn...
So if the car is sitting at +10% in partial throttle (Block 32?) and I add more fuel with the primary the car won't one day return to +10% will it? all i want to know is these changes we make with lemmi won't be undone by the ECU
dkarten
04-15-2011 06:47 AM
maplehawk55
12-16-2010 06:46 AM
brucetimev8
VAG-COM Discussion
02-21-2008 10:14 AM
pureroundcircle
07-12-2005 05:12 PM
Audi mit Höchstgesch
08-09-2001 02:12 PM
Quick Reply: Lemmiwinks question
