Lemmiwinks - timing advance HELP
#12
The login code is 03737. Not 3737 (VAG-Com won't take it) but 03737.
Timing is in channel 9 in adaptation (only after you've entered the login code), the stock value is 128, which equals to 0 degrees. each decimal value above or under 128 equals to 0.75 degrees of timing above or under 0 degrees baseline timing.
The software limits the adjustment to +/- 5.25 degrees only. If you need more, you need a different chip, and I'd suggest the complete chip to be reprogrammed, if you need more than 5.25 degrees above what's programmed in the chip and you don't have pinging.
HTH,
Mihnea
HTH,
Mihnea
audifirst
VAG-COM Discussion
05-07-2007 05:39 PM
