Let's talk engine alternatives again - what are the possibilities for the 3.0L engine in our car?
#71
204-233 hp 3.0L V6 TDI
Configuration
2967 cc wet sumped 90°V6
Cylinders
Bore ? stroke 83 mm ? 91.4 mm (0.91 ratio), 494.5 cc/cylinder, vermicular graphite cast iron block
Head
4 valves per cylinder, DOHC, 17:1 Compression ratio, low-friction roller finger followers with hydraulic valve clearance compensation
Fuel system
Bosch EDC 16, common rail direct diesel injection, separate high-pressure pump and rail for each row of cylinders, maximum injection pressure of 1600 bar, piezo injectors, up to five injection cycles, seven holes
Aspiration
electric variable turbine geometry turbocharger fitted within the inner-V, maximum absolute pressure 2,3 bars, two intercoolers running in parallel, Variable induction tract
Dimensions
219 kg, 444 mm length
Configuration
Cylinders
Head
Fuel system
Aspiration
Dimensions
#74
The 3.0L block weighs in at 60lbs and the 2.7 blk is 105. The cranks are 35lbs each, the 2.8/2.7 heads will fit, along with a S4/RS4 intake. I have to setup the cam timing and check that but I think it will work.
#76
Falcon isn't running this arrangement yet. But he has all of the bits and pieces broken down so he has the best information I've seen so far. Why don't you look at his picture poster if you'd like to see his current engine? :-p
I know of one or two people who have privately expressed a strong interest in trying this. I'm hoping that a few of us can do the project together. That way we can share our resources in sorting out the problems.
I sent you an email a while ago on this topic which you never responded to. You should read your email! :-pp
Stephen
Stephen
#77
personally i prefer disgustingly overbuilt iron blocks, helps me sleep at night ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
i'll happily assist in any way possible to help you guys get 3.0L alu blocks adapted to our platform though!
#78
Sure, it could grenade. But what have I really lost if it does? On the other hand, if it works out I will have quite a nice engine. Plus, it is a neat challenge given that so few are going this route right now.
Anyway, I actually think that the larger crank could mean that the engine is stronger and not weaker. How much of a vulnerability is the block? I've never heard of any of these engines failing because the block failed.
So if I'm going to build an engine (and there are very few built engines out there so far) then it makes sense to build the best engine I can.
Stephen
Stephen
ITALSKIER
10-15-2006 12:35 PM
JoeO
9
02-21-2006 03:10 PM
zafrir
04-22-2003 08:38 AM
