Local Audi tech claims that it's possible to replace aux. water pump without removing IM,
Old 02-27-2009, 04:29 PM
sergeyk's Avatar
Default Local Audi tech claims that it's possible to replace aux. water pump without removing IM,
by removing bi-pipes. He claimed there is enough room to do it through the front.
Did somebody try it?
Old 02-27-2009, 04:33 PM
kelbrig1's Avatar
Default Davenew maybe? I think he has a write up.
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2169710.phtml">https://forums.audiworld.com/s4/msgs/2169710.phtml</a</li></ul>
Old 02-27-2009, 04:40 PM
clinton c's Avatar
Mine was done without removing the Intake manifold.
Old 02-27-2009, 04:54 PM
sergeyk's Avatar
Default Can P/S pressure hose be replaced without removing IM as well?
I have few liquid types there....
Old 02-27-2009, 05:39 PM
Member
KOpork's Avatar
My friend is an Audi Tech and said the same thing to me as well.
Old 02-27-2009, 07:36 PM
Carson (K03x2)'s Avatar
Default You can do it, I've participated in the process.
The bi-pipes have to come off so you can remove the clamp on the water pipe on the front of the engine. You also have to remove the D/S Diverter Valve. They also help gain access to the rear of the engine where the majority of the R/I takes place.
I had never done it before, and when my aux WP blew up I had one of my top techs in the shop show me how he did it.
Old 02-27-2009, 10:26 PM
ming60's Avatar
Default Yep, it's possible. Did it recently using Davenew's writeup
I also did a writeup myself. You need to have all the parts &amp; extra clamps on hand, take your time &amp; be careful not to break any small vac. hoses &amp; connectors in the process.<ul><li><a href="https://forums.audiworld.com/s4/msgs/2847487.phtml">https://forums.audiworld.com/s4/msgs/2847487.phtml</a</li></ul>
Old 02-28-2009, 02:24 AM
PA:CasaS4's Avatar
Default Yup - but the pump comes out the back. It's really not a bad job.
I bought 90 degree needle nose pliers - fairly long - to help squeeze a clamp all the way in the back that was in a tight spot. I'd bet that was the most difficult part of the job for me. I also used davenew's write-up.
Old 02-28-2009, 05:00 AM
davenew's Avatar
yea, definitely possible.
Old 02-28-2009, 05:57 AM
BRK
BRK's Avatar
Default Saw Alex @ Curbside do it...
with ease
Quick Reply: Local Audi tech claims that it's possible to replace aux. water pump without removing IM,
