Local shop tells me Neuspeed sway bars squeak after 5K miles, True?
This happened to me, and several others. A couple potential fixes are:
1. Sand the inside of the bushings with heavy grit sandpaper. Do it in a circular motion so the grooves you create make a circle parallel with the sides of the bushings. Then, regrease liberally with teflon-impregnated marine grease. This is what Neuspeed suggested for me.
2. After trying the above solution, I installed Zerk fittings. No problems since then, and it just takes a minute to regrease if necessary. I personally would do both at the same time since most of the work is just taking the bar off.
it would be a good idea to send us all some grease fittings like the bushings on the H-Sport sways...would make it a lot easier to regrease if we didn't have to remove thge bushings.
