looking for imput on a project im working on. Propane converstion on a S4
#11
Also Ford just introduced the Roushe F-150 that runs on propane. For an extra 10k you can have a propane powered truck. So again why is the S4 not a good idea.
#12
look at their website www.landi.it
There are absolutely no problems with turbo cars.
The only limitations is given by the maximum flow possible, therefore power.
Let us know the maximum power, then we can estimate flow and see if there is a kit suitable.
If you need more informations, just ask.
#15
>and that the pressurized air pushes the gas back to the regulator
false
as long as you are injecting at a higher pressure, you will always inject gas into the manifold
and as long as you stay in the sonic ratio, you will always inject the same quantity independently from the manifold pressure
depends on the pressure the regulator is set with, but usually there is a setting screw
false
schne564
02-21-2012 07:34 AM
Unplugged_A4
08-02-2005 04:14 AM
No More B5 S4
12-16-2002 10:22 PM
