Looks like ModuleMasters ABS repair is in my future...
I had three long beeps, solid ABS light, and flashing BRAKE light a couple times today. I checked codes with VAG and had 18014 Rough Road/engine torque signal from ABS and 01203 Electrical Connection between ABS and instrument cluster. I cleared the codes, but I expect them to come back. Anything else I should check before sending the controller to ModuleMasters? Thanks...
btw those where the exact codes I threw when my module was going out. Keep in mind that if the abs light is on you have no anti lock. If it's not on then you still have abs. It took a few months for my controller to beep on an annoying basis so you have a little time at least.
rip that bad boy out and send it on its way to Module Master. They repaired and shipped my unit back to me in 1 day, and it had worked perfectly since. Removing the unit is super easy too.
KTwo
05-07-2014 01:04 AM
dakota137
04-16-2011 01:36 PM
Omega Supreme
05-18-2008 02:59 AM
algisas
Audi 100 / A6 (C4 Platform)
11-21-2005 07:45 AM
Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
S4Del
12-12-2003 04:23 PM
