Loose front brake pads apparently causing...
...a clunking noise from the front end at low speeds when starting and stopping. I eliminated many other things and today found that the inside lower front brake pads on both sides can be moved by hand and make the clunk I have been hearing. These are stock pads with about 5/16" left on them. Is the noise normal? Will changing pads fix this? TIA
It holds on even when the front rotors are glowing and the pads are sparking
<ul><li><a href="http://www.permatex.com/auto/autoext.asp?automotive=yes&f_call=get_item& ;item_no=80729">http://www.permatex.com/auto/autoext.asp?automotive=yes&f_call=get_item& ;item_no=80729</a</li></ul>
... because I did a little test with the emergency brake. Using only the emergency brake to stop a low speeds, I got no noise, but with the brake pedal, the noise is there. I believe that the emergency brake only uses the rear calipers.
i also get this clicking/clunkying sound when i apply pressure to the brakes. but my brake pads don't move as you described.
i haven't been able to find out what the problem is, but please do let me know if you fix your problem. thanks!
Audi_Sport
04-27-2001 01:09 PM
