loosing boost? how long do stock diverters valves last?
hae3 78k on the car, it seems to be slowing down, has the stock valves still. non chipped. any easy way to tell? also where is the best place to tap the vac line for a boost guage?
push the piston on the bottom side, put your thumb over the vacuum side nipple. If the piston snaps back to it's resting position once you release it, there is a hole in the diaphragm, and it needs to be replaced.
internal diaphragm. But for aftermarket valves, you can have other situations like a sticking piston, which you may not discover when performing this test. I'd say it's definitive when dealing with an OEM/Bosch valve, but not definitive when dealing with aftermarket valves.
You'll need a vag.com (www.ross-tech.com) in order to log block 115 which contains the aforementioned values. Take a full throttle run in 3rd gear while logging that block from 2K rpms on up to 5K+rpms.
Plot the resulting logs in a graph and look for significant deviation (indicating the ECU is requesting boost, but the actual values differ greatly).
A simpler way would be to hook up a boost guage (fuel pressure regulator has a vac line you can run a "T" fitting off of), record peak readings, and compare them to "the norm" for the level of modification your car has.
SilverisFaster
01-17-2002 07:30 PM
chisilvertip
05-02-2001 11:40 AM
