Losing a considerable amount of Boost in Upper RPM range.
Okay--
I have a strange problem that I am trying to trace down.
First off.. The car is Stage2+ which just means that I am running:
AMS Chips
Piggie pipes
No Cats
Borla Exhaust
Here is the problem though.
In the lower RPM--say till about 4K the car boost properly--spikes to about 18-19psi, then gradually tappers down--not much, but then after 4K, it tends to tapper down to around 10-11psi. Do you think this could be a small boost leak???? I did a pressure test and could not find any leaks, so now I am at odds to what the problem could be.. Any insight will help.
Thanks in advance..
AMS Chips
Piggie pipes
No Cats
Borla Exhaust
Thanks in advance..
cats or not does not determine what stage you are. And please make use of the subject line at all times.
