low oil pressure questions
I recently did a turbo swap for a fellow forum member and after reassembly the car is displaying the low oil pressure light. Where is this pressure sensor located? I pulled the oil pan to make sure there wasnt any debris clogging the pickup screen and there wasnt. Can anyone offer a good method to pin point where the problem is? Where could I hook up a oil pressure guage to get a good reading? and finally what type of sealent should i use when re-installing the pan
TIA
TIA
The wire leading to the sensor can be in the way when the a/c compressor is removed during an engine pull.
Dave
Dave
Libtek13
08-04-2004 09:45 AM
Jaredg
11
02-18-2004 11:38 AM
