Lower boost for better gas mileage?
Old 10-28-2001, 05:33 PM
New Member
alanaudi's Avatar
Default Lower boost for better gas mileage?
I recently sent this email to APR (ECMS program):
Do you have an engine program for lower turbo pressure on the S4? I drove a 91 200TQ from NH to MD and got 27mpg only to find out that the wastegate freq valve was bad causing under boost. I thought it would be a great idea for long highway trips. Thoughts?
Any comments/thoughts?
Old 10-28-2001, 05:38 PM
Member
Nogaro's Avatar
Default That would be a great idea!
When I had a chip I didn't see any MPG drop. Not sure if its even worth it.
Old 10-28-2001, 06:07 PM
donp's Avatar
Except that at steady speed you're not using boost anyway. Boost is only under acceleration.
Old 10-28-2001, 06:17 PM
New Member
alanaudi's Avatar
I wonder if lower boost raises MPG though...
Old 10-28-2001, 06:18 PM
New Member
alanaudi's Avatar
Default On a long highway trip, you accelerate but don't need boost...
so, it should raise MPG.
Old 10-28-2001, 06:20 PM
New Member
Ira B's Avatar
Default Boost is directly related to right foot action
You can accelerate gently (not too much throttle, slowly applied) and use little or no boost. A low boost option in a chip is about the same as a block under the gas pedal. Just take it easy and you won't use much boost or much gas.
Old 10-28-2001, 06:25 PM
New Member
alanaudi's Avatar
Default Re: Boost is directly related to right foot action
When I posted my MPG from the 200TQ trip, someone replied that there must be something wrong with the boost because my mileage was so good. I realize *if* I drive like there's a block under my gas pedal I'll make better gas mileage. I wonder if a lower boost car will make better gas mileage on a long trip versus just "being careful" with your right foot.
Old 10-28-2001, 06:36 PM
Member
Nogaro's Avatar
Default Somewhat unlikly..
maybe the chips just run the engine a bit more on the lean side, so more power but no increase in MPG.
Old 10-28-2001, 08:24 PM
AudiWorld Uber User
PhoenixGTS's Avatar
Default No. On the highway the car is not making boost until the wind resistance is so high that the car
actually ahs to make power to push through. I do not know how fast that is (any help from someone with a boost guage?), but I bet it is around 80 mph or more. So cruising at 70-75, the maximum boost that your ECU might call for has no effect on your gas mileage.
Old 10-28-2001, 08:42 PM
New Member
alanaudi's Avatar
It's not 100% cruising at constant velocity... passing, etc. completed under boost
Quick Reply: Lower boost for better gas mileage?
