Lug bolt question
Lug bolt question
i have 15mm wheel spacers which i just installed, use my stock wheels with longer lug bolts. the place i got the longer lug bolts did not have the specific type of lug bolts required for my winter wheels and tires. the lug bolts i need are not conical and not the other common type (forget the name) any ideas as to where i can purchase lug bolts. i think the wheels are asw..
is there another type because they are not those its....
like the cone seat but the head of the bolt in narrower<ul><li><a href="http://www.purems.com/images/products/fullsize/bolt_styles.jpg">http://www.purems.com/images/products/fullsize/bolt_styles.jpg</a</li></ul>
Former Vendor
No.
If the head of the bolt is simply just smaller in diameter, you may have "tuner" bolts. If so, you might not be able to use regular wheel bolts, but it would depend on the bolt hole for the wheels.
it all depends on the wheel itself
So, make sure you get the proper length lugs with the correct seat for your wheels. It's pretty easy to determine the seat type by looking at the lug bolt contact area on the wheel.
Most tire stores can order the bolts if they don't have them in stock.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Fwheels%2Ftech%2Fnutsandbolts.ht m">http://www.tirerack.com/wheels/tech/nutsandbolts.htm</a></li></ul>
esanmiguel
04-10-2006 04:50 PM
CTA4AVANT
05-08-2004 09:21 AM
Trent
06-19-2003 10:22 AM
