MAF and injector size for homebrew using hybrid turbos
#15
@ the moment
568cc/min - 42lb Greentops w/5bar 63% larger than stock
90mm maf= 45*45*3.1416= 6361.74= 52% larger than stock
Any problems with 90mm @ idle and misfire?
#18
Re: That'll work. That's the same setup that we put in Uli's car. He's at -11pri now, no codes.
Using Fuel Injector Flow Calculator
Enter Original Fuel Pressure 43.5 (is this stock fuel pressure 43.5?)
Enter New Fuel Pressure 72
Enter Rating Of Fuel Injector (lb/hr) 42
New Flow Rate Of Fuel Injector 54 lb/hr
567 cc/min
Isn't this a bit crazy, to be pushing an injector that was rated @ 42lb @54lb ?
Edy
567 cc/min
Edy
#20
Nope, fine. Those injectors (and most Bosch squirters) are rated @ 5bar, but the delphi's are not.
It'll be hell on the stock fuel pump though: It has to flow more volume at a greater pressure.
