MAF screen removal questions for those that have done it...
Did you remove the MAF sensor from the MAF housing or did you try to take the screen out without touching the sensor? I found one post where someone just laid it flat on a table and punched it and the flow straightener out, then re-installed the plastic flow straightener.
I don't have the right tool (looks like a keyed torx) to remove the sensor from the housing. Anyone know specifically what I need? I was thinking I could just remove the sensor, but it in a baggy, and then take my time on the housing. Any ideas?
Thanks!
-st
Thanks!
-st
You should be able to pick one of those up at check or your local tools speciality shop. I believe it just has two s-torx bolts then the sensor should pull straight out? Good luck.
myfootsmells
05-25-2005 04:45 PM
Arcteryx::Stock Rods
05-04-2005 08:25 PM
When doing a MAF soak, do I need to remove the sensor from the housing, or just dunk the whole thing
Naptown::KckblAlstr
09-21-2004 02:44 PM
maxma
12-31-2002 06:55 AM
changs4
05-27-2002 03:20 AM
