Magnetic Fuel Ionizers...
#22
if you dont use a spark inducer with it, it wont work.
first put in the field ionizer, then put in the spark inducer.
the spark inducer "pre-sparks" the fuel for easier ignition. just an fyi, this isnt CARB legal.
#24
Where would you place the spark inducer?
I think it works best inside the gas tank, that way it has plenty of time to pre-spark on it's way to the cylinder. But that causes a problem as to where to place the field ionizer.
#25
you are right, depending on altitude, a spark inducer in the tank is the best way to go.
it works the best when there is a 14:1 air fuel mixure in the tank.
in this case ive seen a nipple welded off the fuel filter for the field ionizer.
Cipher5170
06-28-2003 12:53 PM
Power5
08-16-2001 10:24 AM
