Message to all S4 people(especially NJ), Autolock Pro Wide DOES fit our cars
you just need model 1660. Its available at PEP Boys, and is designed specifically to fit certain audis, VW's and older porsche's. Keep in mind I have a tip S4 so I put it on the brake pedeal. HAve not tried on a manual S4's clutch or brake pedal yet. Fourth of july is here soon and i'm headed down to S4 thrft ground zero, just thought i'd shre the extra protection i just got...keep i mind the best way to rpevent theft is multiple measure of defense which can include the autolock or club etc.
oh btw, the people at the website that sells autolock (forget teh URL) are idiots...they didn't even know this model existed when i called them a couple months ago. i just happened to find this while i was picking up some oil at the Pep boys.
be cool to have a fellow audi perosn's company...e-mail me with hw to get in touch with you. thanks.
When it is "automatic" it goes on the BRAKE pedal, because you cannot shift otherwise...
When it is "manual" it goes on the CLUTCH pedal since you cannot shift or start the car otherwise ! ! ! !
Just my .02 cents
Nick Kourasis in NJ
S4 Avant
Just my .02 cents
Nick Kourasis in NJ
S4 Avant
I put it on the brake lever because it's hardened steel, while the clutch lever is aluminum, which is much easier to cut through. After cutting through a lever, it wouldn't be that tricky for them to put together some sort of temporary pedal replacement ... so that's why it's on the brake.
That with a free clutch, they can start the car and with a usable E-brake they can stop it?
If they want to rip you off, they can run it a few blocks and strip the hell out of the car and leave it there with the lock on !
Does this lock also uses the Steering Wheel, because if not, it is a waste of money.
The one I use from Autolock (I brought it from Greece for my I-Mark), you put the E-brake up on the highest position, insert an SS tube onto the E-brake and with it lock the shift lever at the Park position (I have a Tip)Cannot shift and cannot release brake. Too bad when I had it on the I-Mark it was still in the box in the trunk... Oh well, car survived that...
Nikos Kourasis
01 S4 Avant
Nikos Kourasis
01 S4 Avant
M what?
11-22-2002 04:35 AM
riceboy22
07-01-2002 12:47 PM
Can someone tell me how they get their autolock to fit. My pedals are too big, yet I read over and..
silvertiger
05-06-2002 01:52 PM
HDClown
04-30-2002 06:25 AM
