Misfire on Cylinder 5 and Cylinder 2
Well driving around the city(SF) last night and then the Check Engine light came on.
Pulled out the VAG and recieved 3 codes, one was random mis fires and one for cyclinder 2 and one for cylinder 5 misfire.
I cleared the codes and for two days they have not come back.
I have 67,000 miles/6 speed/MTM stage1
Is it common to get misfires and have them go away?
What do you guys suggest I check first if they come back?
Plugs? CoilPacks? Anways, thanks for any feedback
How difficult is it to swap coilpacks?
-Joe
-Joe
If the misfires come back, I'd swap one out with a cylinder that isn't misfiring. If the misfire follows the coilpack... Super easy diagnostics.
Of course, If you haven't changed your plugs in a while...
So I can't really tell you what you need to do to fix it. I can tell you a new coil pack probably won't solve the problem as you have described it (and it may not necessarily be a problem, but you haven't quantified the problem very well either, so I'm not going to waste my time speculating).
Some people have observed random misfires under these circumstances, and a new CTS solved it. It's a $5 failure prone part and a 20 minute install.
Start with the CTS, and if that doesn't help, yank the plugs on 2 and 5 and evaluate their condition. If you think they are bad (post a picture of them here if you're unsure), order new plugs and install them. Most of them are easy to get to...1 or 2 are blocked requiring you to move a few things to get access.
