Moneypit Motorsports : Another log from yesterday
Old 09-13-2006, 10:17 AM
  #21
BLK01S4's Avatar
Mark I am wanting stage III tip software from jew. Make me some bish!
Old 09-13-2006, 10:18 AM
  #22
BLK01S4's Avatar
Default Nope
Greentops @ 4 bar
90mm MAF
Apexi AVC-r
Old 09-13-2006, 10:40 AM
  #23
Godfather | Jay's Avatar
What happened from 6000-6200?
Old 09-13-2006, 11:16 AM
  #24
cjk
cjk's Avatar
Default You thinking of trying anything bigger for injectors?
Just wondering...what boost r u running?
Really weird man- cause I was maxing out my greentops when I was holding around 24psi...like above 150%...
Hmmm....interested in possibly something in between the two for me cause my LTFT's are waaaaaaaay toooooooooo rich. -25%
Old 09-13-2006, 12:15 PM
  #25
Chuck-S4's Avatar
I would pull way more primary... even if the A:F seems nice... you would be surprised...
Old 09-13-2006, 12:26 PM
  #26
BLK01S4's Avatar
Default Well ..
I'd like something bigger then Greentops not sure what else to use. I think moto's are too large but I like the spray pattern. I have an RS4 fuelpump it must crank out some fuel to keep up with this. Have you considered Greentops @ 5 bar or soemthing?
Old 09-13-2006, 12:27 PM
  #27
BLK01S4's Avatar
Default -10%?
I think that run me close to 12.8? To lean?
Old 09-13-2006, 12:31 PM
  #28
BLK01S4's Avatar
BTW thanks for the e-mail about the 5bar!
Old 09-13-2006, 12:35 PM
  #29
Chuck-S4's Avatar
Default Well, here is my experience...
Removing another 10% of primary, for ex., doesn't produce that much of a difference on the A:F curve (that is my experience...). It's not like "1+1=2" ... it doesn't have a full impact on the fueling, the ECU still compensates...
I had a setup similar than you last year... so that's why I would try -15% straight off the bat ; like said in my message, the ECU can compensate +/- 25% so you're not in %%% sh%% in trying this, as your MAF Housing / Fueling combo in inline... I was using settings between -15%/-20%, using a similar Stage 3+ setup, with great results...
Old 09-13-2006, 12:39 PM
  #30
Member
PSmalls::AnalRetentiveNumbNut's Avatar
Huh? ECU compensating at WOT?
Quick Reply: Moneypit Motorsports : Another log from yesterday
