Moneypit Motorsports : Another log from yesterday
#41
think and you'll figure it out BS.
Basically if your MAF scaling is on the large side (Ie. you're running a 90mm and not flowing alot) The MAF/Load output seen by the ECU, still keeps you in CLOSED LOOP.
It gets a little more complicated, because Throttle Position does play a part, but lets just say for fueling sake, it is possible to be in CLOSED LOOP at 100% Pedal and never enter the OPEN LOOP mode.
#42
I have noticed if you get to 200g/sec you get into open loop quicker or at least at all. Check out my other post with more data you can see my timing / fueling gets better as I do this. Where is my stage III tip software ?
#43
I've talked about low MAF readings keeping you in closed loop at WOT before on here, just not pertinent to this conversation since BLK01S4 is flowing plenty.
Sorry, I don't see how your post has an ounce of relevance.
BLK01S4
39
09-12-2006 08:08 AM
aerohr
03-25-2006 12:47 PM
iraicu
11-15-2003 02:50 PM
DirtySoap
09-10-2002 03:51 PM
