More RS4 clutch thoughts...
First off the car has been driven less than a hundred miles since the clutch was put in. My first impression is how the low in the pedal action the clutch engages. I moved my seat up because for smooth shifting you really have the press the clutch all the way to the floor quickly. The clutch will reengage by lifting the pedal a couple of inches off the floor. By the time the stock clutch had worn out it engaged at the top of the pedal action, completly opposite from what the RS4 is set at. I know these are self adjusting clutches so do the techs set the clutch to start low in the pedal action and as it self adjusts the pedal action moves to the top?
I find that the clutch engagement is quite abrubt on the RS4 clutch and getting really smooth shifts has been an issue. It must be the increased clamping force that I am not used to. Point of reference, by the time the stock clutch had worn out it would slip with my boost gauge showing any positive manifold pressure.
For now I am taking it easy as I break the clutch in. It is very grabby compared to the stock disc. The 1-2 shift can easily jolt you in the back of your seat, you can be nasty with this clutch. Once it is broken in I will update.
My car has 60k on it, so I figure the clutch has to be getting old. Should I get an RS4 or just get another OEM...
The engagement point and weight were about the same.
It was a lot less noticable than the new turbos I got installed at the same time
RSAVIPER
03-13-2006 07:13 AM
rktskicar
17
01-23-2006 08:08 PM
senseigmg
12-30-2005 04:31 AM
