More stuff to add to the pile...
<center><img src="http://pictureposter.audiworld.com/38083/vogts.jpg"></center><p>They made the cross-country trip fine. Thanks Tomasz!
The PCV purge on the Y pipe is really the only line I'd be concerned with. You can just splice into it.
My sedan never had a PCV oil issue, so I had no need to create one, my Avant might need one though. I'm considering doing a duocyclone separator with a check-valved passive crankcase drain.
I also capped the spider hose connection to the intake manifold. Put in a hose with a check valve from the intake manifold to the output of the catch can and limiting valve via a T connector so that the intake manifold gets "filtered" air.
The check valve will let air to be sucked-in by the intake manifold but it also sucks air in from the Y-pipe/limiting valve connection.
For troubleshooting purposes, I reversed the check valve so that the IM won't sucked in air from the limiting valve/Y pipe but my boost won't go past 15psi. You think I would just cap both spider and intake manifold and get rid of that extra hose? Is there enough vacuum in the Y pipe to keep the pcv system working?
it looks like I gotta do this:<ul><li><a href="https://forums.audiworld.com/s4/msgs/2515240.phtml">https://forums.audiworld.com/s4/msgs/2515240.phtml</a</li></ul>
Island Boy::Jeproks
04-03-2007 06:24 AM
4Driver4
07-19-2004 02:38 PM
StevenH
Performance and Tuning
06-07-2003 08:24 PM
Jenner
02-11-2002 06:21 PM
