Motor rebuild, now complete. Now audi has discovered the passenger side turbo is DAMAGED
The saga that has become my worst nightmare, just keeps getting better.
Ok... Audi called me to tell me that the motor work has been completed. For those of you who are just now joining this story please see for full update
https://forums.audiworld.com/s4/msgs/988787.phtml
So now they have determined that the passenger side turbo could 'possibly' be damaged, either by the following
1- when the heads blew it could have sucked a fragment of metal into the turbo housing causing damage to the turbo blades
< OR >
2- My BOV's isnt allowing the air from the turbo release so therefore its damaging the turbo
My opinion is that #2 is total CRAP since isnt is a coincidence that they discovered this right when my heads blew??
So today they are going to take the turbo out, put a bore scope in it to see if there is any damage to the blades caused by flying pieces of metal from a damaged valve. If they determine that the blades were damaged then they are going to replace both turbo's with NEW ones. If not then i get stuck with the repair cost. Not Good..
Still awaiting the final outcome.. will keep posing !!!!
< OR >
It is sometimes hard to tell what the problem really was and the source of the failure is determined by the people with financial interest not to pay.
The way it should be is... The turbo may have failed because:
3- Thinner oil supply lines in 2K turbos.
4- Something else we could not find.
The aftermarket part should not be a catch-all for all the problems. They should show exactly why the part caused the turbo failure.
THANK GOD everything so far is covered under warranty.. Plus i have an additional 3 year extended warranty on the car..
With rebuilding the motor, parts, labor and time
rough estimate is around $8500-9200
Now if the turbo's need to be replaced then thats going to be $3k or more added on..
Id also have the car checked by an independant mechanic on their lot before you drive off...Compression test/leakdown/visual inspection/vag testing etc! They whacked your engine out due to incompetance and they want to still play games what a bunch of A$$holes!
