Mototron pics, videos, injector roundup
Old 04-04-2006, 09:15 AM
  #71
OCA::DIY Motorsports's Avatar
OK thanks. Guess I should talk to Mike2ks4 since he is running that set up..huh?
Old 04-04-2006, 09:20 AM
  #72
AudiWorld Expert
Captain Matt, I be's Avatar
pencil streams from the pics not sure if Mark's injectors are the same ones.
Old 04-04-2006, 09:27 AM
  #73
Senior Member
Nick Gustas's Avatar
Default Seemed a bit wierd on part throttle and didn't help cold misfires any, could have been my lack of
tuning time, I didn't really give them a chance.
$180 shipped, they are yours
Old 04-04-2006, 09:49 AM
  #74
lemieux@curbside's Avatar
Default i remeber seeing a vid of them and the patern was nice and wide .. am i wrong ?
milpitas posted the vidoes of the 37 and 42 lb dephis...<ul><li><a href="https://forums.audiworld.com/s4/msgs/2276935.phtml">https://forums.audiworld.com/s4/msgs/2276935.phtml</a</li></ul>
Old 04-04-2006, 09:54 AM
  #75
AudiWorld Expert
Default yeah looks wide there, but the pics Nick posted look pretty thin
listed as '42lb bluetops'
I think green giants are your best bet though
Old 04-04-2006, 10:06 AM
  #76
Senior Member
Default Looks the same to me, keep in mind it's a 3 jet injector, I didn't capture it well.
One of the other google videos on there "42lb #1" is one of mine made with the same injector in the picture in my original post.
<a href="http://tychl.txf.com/mototron/42lb%20delphi%20bluetop.avi">Watch the video if you haven't</a>
<a href="http://tychl.txf.com/42lbdelphi/42lb%20delphi1.AVI">Here's an older video I made of them.</a>
Also my shots showed the stream over a longer distance, measure the angle with a protractor and I bet it'll be close.
Old 04-04-2006, 10:21 AM
  #77
i see .. if they didn't work for you , they are not going to work fer me either ;(
Old 04-04-2006, 10:22 AM
  #78
Default how much do they go for tho' ? may as well bend over and get rs4
or even better - sell everything and go with ASP.. and be done.
Old 04-04-2006, 10:24 AM
  #79
AudiWorld Expert
set of four for ~$290
Old 04-04-2006, 10:29 AM
  #80
Elder Member
PSmalls::DoggieStyle's Avatar
Default Many have had success with 42# and 38# Delphi injectors. If tweaked well, pretty much flawless.
Lemieux, you should really get a wideband. That would be extremely benefitial in tweaking your setup probably.
FWIW, I've seen a couple cases where too rich of a mixture causes high CFs, popping on decel, and other issues. In that case, leaning it out may actually drop CFs, increase overall timing advancement, eliminate any popping and/or misfiring...resulting in increased drivability and performance.
Without a wideband, it's hard to say exactly what's going on. The more and more I see wideband data, the more and more I don't trust narrowband info.
Quick Reply: Mototron pics, videos, injector roundup
